Inverted reading
kbishop
I have a new panel with a Dynon 10A installed. At first the unit worked fine when powered up however now when the unit is turned on it workds o.k. for about 4 seconds then the display switched to inverted. Any suggestions?
Give us a call at 425-402-0433 and ask for tech support. That sounds like a problem that we'll need to fix here.
hennie
south africa
hi installed a new efis-d100 on the ground when my plane is level the horizon line is level when i fly the horizon line is about 7degree out i have to lift my right wing to get my horizon line strait . how do i fix this
The only install problem that we know of that could cause this is excessive vibration, or an EFIS that isn't square with the wings. Make sure the D100 is securely mounted to the panel and doesn't resonate. Also make sure that the D100's screen is exactly parallel to the wings.
If these things aren't the problem, you'll need to give us a call and we'll probably need to get the unit back to check it out.
