IO-540 Tach Setup
f5ftiger
Hamburg Germany
Please help!!!
I have an IO-540 (6Cyl)with Bendix S6LN magnetos. I have connected the Dynon 180 to the mags as discribed with the resistors supplyed.
1. What pulse/rev setting do I need? (dont get it what the manual says :'( )
2. Are the resistors enough?
3. Can I test it without runing the engine? when I try to test it by cranking the RPM shows 9999
Thanks for the help!
Christoph
1) You probably need 3 pulses per rev, but you might need 1.5.
2) Don't know what you mean by "enough." Enough for what?
3) No, the engine needs to be running normally to test.
