Jabiru 2200 tachometer wiring
bdirdal
When connecting the tachometer sensor wire to the alternator wire how many pulses should be entered in to the EMS set up?
Borge
I think it's 6 PPR - try it and see ;) or change it to another setting, you can do this while the engine is running.
BTW - if there are unstable rpm fluctuations I'd use an 100k oHm
resistor.
Jake J
