Kaviloc PE2000
Pegaz
France
Hi,
Is the SV compatible with the Kaviloc PE2000-5064 pressure sensor ?
Thank you
I believe you mean the company Kavlico. I looked online and found no references to a Kavlico PE2000-5064. Can you please point us to a datasheet for the part?
Pegaz
France
Specification PE2000-5064
1. INPUT
INPUT PRESSURE RANGE : 0 PSIA TO 100 PSIA
PROOF PRESSURE : 200 PSI MAX.
BURST PRESSURE : 300 PSI MIN.
OPERATING SUPPLY VOLTAGE RANGE (Vs) : 5.000 ± 0.250 VDC
BUILT-IN REVERSE POLARITY FOR 5 MINUTES.
2. NOMINAL OUTPUT VOLTAGE AT 25°C: (CALIBRATED AT Vs= 5.000 ± 0.002 VDC)
1.734 VDC @ 10 PSIA TO
4.660 VDC @ 90 PSIA
3. ACCURACY:
TOTAL ERROR: SEE FIGURE 1.
TOTAL ERROR INCLUDING LINEARITY ERROR, HYSTERESIS, REPEATABILITY
AND TEMPERATURE EFFECTS FROM –40°C TO 125°C.
4. RATIONMETRICITY ERROR IS WITHIN ±1.5% OF FULL SCALE OUTPUT OVER
4.750 [ch8804][ch61472]Vs [ch8804][ch61472]5.250 VDC AT ROOM TEMPERATURE.
5. EXCITATION CURRENT : 5 mA MAX.
6. RESPONSE TIME : 15 ms MAX. TO 63% OF FULL SCALE
PRESSURE WITH STEP CHANGE ON INPUT
7. OUTPUT IMPEDANCE : LESS THAN 100 [ch61657]
8. MINIMUM LOAD RECOMMENDED : 25 k[ch61657]
9. ENVIRONMENTAL
OPERATING TEMPERATURE RANGE : -40°C TO 125°C
STORAGE TEMPERATURE RANGE : -40°C TO 125°C
VIBRATION : 5 G`s PEAK TO SINUSOIDAL (10 TO 500 Hz)
SHOCK : 75 G`s ½ SINEWAVE
10. RELIABILITY
EXPECTED OPERATING LIFE : 10 MILLION FULL PRESSURE CYCLES MIN.
SHELF LIFE : 10 YEARS MIN.
11. MEDIA : ENGINE OILS / HYDRAULIC FLUIDS
12. SEAL MATERIAL : FLUOROSILICONE
13. HOUSING MATERIAL : 303 STAINLESS STEEL AND CONNECTOR
WITH BLACK ZYTEL 77G33L (33% GLASS FILLED).
14. WEIGHT : appr. 60 g
15. EMI PROTECTION : MAXIMUM CHANGE IN OUTPUT DUE TO RF FIELD OF 200
V/M FROM 10 kHz TO 1 GHz IS 25% OF FULL SPAN
WITH COMMON MODE PROTECTION.
16. ELECTRICAL TERMINATION : BUILT IN CONNECTOR MATES TO PACKARD
ELECTRIC DIVISION (PED) METRI-PACK 150 SERIES SEALED CONNECTOR
#12065287
17. RECOMMENDED MOUNTING TORQUE : 40 Nm MAX. (29.5 LBS-FT)
That is not a sender we support. We support (and sell) the Kavlico 5, 15, 50, 75, and 150 PSI sensors.
