Kavlico Fuel pressure does not work on both screen
Tomyfly
I installed a new 15 psi Kavlico fuel pressure sensor, the 5V are coming from manifold pressure sensor. I am using pin 8 from ems, the same with I used for the older VDO sensor. I coud see the old sensor on both screens.
1. Problem: I cannot configure both screens only one is able to read or see the sensor
2. Problem: The fuel sensor works fine on ground. But when I fly higher the fuel sensor is showing less values, above 10.000 ft the pressure is near "0"
Could the reason be air in the hose/ tube to the fuel prssure sensor?
Tomyfly
The problem had a solution: There wher different versions of the EMS file on both sreens ..... ::), now it works fine!
