Kavlico Pressure sensors
Battson
Bearhawk
Probably a silly question.
I have the Kavlico pressure sensors, fuel and oil. They appear different to the ones in the install manual, they have three wires (red/white/green) but the manual only addresses one wire and talks about case-grounding which I thought does not apply to Kavlico sensors.
Where would I find the instructions for connecting them?
Mounting is already sorted.
You should have received paperwork with them about installation - however, black is ground, red is 5vlt excitation (ie same white/red wire that goes to MAP, can be joined to it) & green goes to the sensor input as per the 'old' sensors.  You will have to tell the Dynon what type sensor it is.
Check this link http://www.dynonavionics.com/downloads/Install_Guides/Addendum_Kavlico_Sensors-Rev_B.pdf
HTH
Jake J
Back
