KX125 to D100
Ken
I am installing a kx125 to KN72 and KN75 and Dynon HS34 to Dynon D100. Both the KX125 and the KN72 will output CDI +/- and TO/From. The HS34 supports both CDI +/- and LOC +/-. Neither the KX125 or the KN72 has an output called LOC +/-. I think the CDI +/- maybe the LOC +/- when ILS Energize is activated. Should I use the output from the KX125 or the KN72 to the HS34. Should I connect the CDI + to the LOC + and the CDI- to the LOC- also. The KN72 is mostly to support the OBS resolvers I think.
Ken
jnevesjr
I have a 125 and went down this path a year ago, I was never able to get it to function. Sounds like Dynon never completed the development for this integration. The only navs that can be used from the research I did was the Garmin/Apollo SL30 and the VAL 2000 Nav only. Thee 2 communicate with the ARINC 429 ports on the HS34.
Ken
Thanks for the reply. I plan to use the KN72 for only the resolver function and use the KX125 for the flags, CDI and LOC. Did this approach not work either?
Ken
jnevesjr
Since I couldn't get clear direction and the majority of the reply's on a few forums and from Dynon, the ones I did get pointed to it not working for sure. I just abandoned the idea and saved up to replace the KX125 with Garmin's GNC 355 IFR GPS/COM. Working in the install now, it's a much better solution over all and much easier to integrate via the ARINC connections.
