1. What should I do with the wires from pins 11, 12 and 30?
2. Pin 31 is an audio alert. What do I do with it? I'm using both D10 EFIS and EMS. I don't have the green wire, pin 18 from the EFIS connected to anything either because I didn't know what to do with it. I have a Garmin 396 connected to the EFIS with data feed and have the two Dynon units now connected by the pins 4, 5 and 34, 35. Should I have one or both audio outputs going to what to have alerts?
3. Am not using pin 16 ground wire. Should I just remove it from the connector or seal the end and leave it under the panel?
Thank you for all the help!!
