Left Screen Problems
timfwalsh01
Alexandria, VA
Dynon,
I recently received my EFIS-D10A back from service.  I had problems with the system after updating to 5.1.1  I installed, and it was great to see it come back to life!!
While checking the settings, I had the RPM and clock on the left side of the screen, with the OAT settings on the right.  All worked well.   The data was displayed correctly on the left and right sides of the EFIS.
When I started to change different data fields (using EFIS > INFO > LEFT menu) from the left to the right side of the EFIS, the left side stopped working.  I cannot display anything on the left side.
The clock does not display either.
All data fileds work correctly when displayed on the right side.
Any suggestions?  Thanks  Tim
I assume by "not working" you mean "not displayed"
This will be true if you have the glideslope displayed on the EFIS screen, even if the GS is not currently active.
Go into Setup->Clutter and change what I assume to be "CDI+GS" to either CDI:N or CDI"Y. Then you can have info items on the left side.
