I am wanting to doublecheck some of the limitations of the D120...
I see in the install manual that when you are not using an HS34 and you have both a D100 & D120 and you connect a GPS to the D120 and a SL30 to the D100, you cannot see SL30 data on the HSI when displayed on the D120. Is this a limitation when using the HS34?
I also see that the Economy data is not available on the D120 when the SL30 is being used as a source for the HSI on the D120. Is this a limitation when using the HS34?
Are there any other limitations on what can be displayed where when using a D100&D120 combo instead of a D180/D100 combo other than you only have one EFIS?
