loading current Aviation and Ob databases
petep
I am getting a warning that my navigation database is out of date. I downloaded the av_data_FAA_5.0_1303.dup and ob_data_FAA_5.0_1302.dup files into the root of my USB stick. When I install the memory stick and go into the Skyview setup to load the files they don't appear on the list of files. Any clue where I am going wrong?
Garrett
Tampa Fl
Try another memory stick or delete/reformat everything off the original Dynon stick and then reload and then it should work. I experienced the same thing.
petep
Worked fine afer deleteing everything from the stick and downloading the two files to the stick again. ThanKs for the help Garrett.
