Localizer inner and outer markers.
cbretana
I have a VAL NAV 2000 wired into my HDX display. When I cross over the outer and/or inner markers, should I be getting some indication on my display? Or do I need to install an additional light on the Panel hooked up to an output ssignal from the NAV2K or tHe HDX?
Carl_Froehlich
Your Val Nav 2000 does not have a Marker Beacon receiver. If you really want one (few people do anymore) you will need to buy one, add a Marker Beacon antenna, indicator lights and wire the audio to your audio panel. The other option is to replace your audio panel with one that has a Marker Beacon receiver built in.
Carl
cbretana
So then does that mean that with my equipment, the only way to know when you are at the FAF, or the MAP, on a localizer approach when these points are defined by narker beacons and DMEs is using GPS DME?
And that would be FAA legal because although the Dynon GPS 2020 is not a certified GPS navigator it is okay to use it for DME?
kurtfly
I would guess NO- the GPS 2020 is not a legal GPS position source for IFR navigation. You need to have a IFR navigator, like GNS430 or IFD 540, etc....
