Rocky_W
- Joined
- Oct 6, 2019
- Messages
- 8
Hello
I had GPS data from my Garmin 696 feed into my Dynon Skyview which allowed me to fly a route on the autopilot. The GPS data was also used to fly a trach on my autopilot.
On a recent flight I noticed that the data from the 696 is no longer showing on my Skyview screen and I could not use my autopilot, as my autopilot is using the GPS data from the 696. I then checked the 696 and I found that is had lost all historic data. I assume I must have drained the battery by mistake. I set up the 696 again and configured the Interface as NMEA Out/In and the BAUD rate as Normal which should give a BAUD rate of 4800. I found this on one of the forums.
Then in the Skyview it is set up under the serial port setup as port 3. I've made sure that the Navigation Source Display is (Not set) and Serial Out Device is set to None. On the Serial in function I have GPS 1 - Serial port 3 and POS 1 - Serial port 5.
On the setup screen on the Skyview it is showing (but it is grey so I can't change it) that the BAUD rate in / out is 9600. So I also tried setting the Garmin's BAUD rate as Fast. That made no difference.
I have not flown since changing the settings, but I get no distance information on the Skyview screen with a leg on a programmed route activated on the 696 and the distance to the next way point showing on the Garmin (but not on the Skyview).
I had this issue before just after buying my aircraft, but I can't remember how I resolved the issue. Any advice welcome. Thanks!
Roger
Roger
