Page 5-8 has the following to say:
"In the EFIS > SETUP > CLUTTR menu, you can turn on or off almost every item displayed on the EFIS page. As with all other menu items, these options are abbreviated to commands containing 6 letters or fewer. Pressing a button corresponding to one of these options turns the respective onscreen item on or off. The following table summarizes the display item abbreviations and their function."
We use this terminology throughout the manual, like EFIS->SETUP->CLUTTR, which means enter the EFIS menu, then press setup, then press CLUTTR. This is the best and shortest way we know how to tell you exactly how to get to the option we are discussing. The table below then says:
VSI
Vertical Speed Indicator
Toggles and configures the display of the VSI tape next to the altitude tape. The VSI can be hidden (“N”), or can be set to 1k, 2k, or 4k ft/min scaling. The 2000 ft/min display is linear throughout the range, while the 1000 and 4000 ft/min displays incorporate a non-linear scale to increase low vertical speed resolution.
It is very handy to search the manual for the thing you are trying to work on. If I search the user manual (not the install guide) for VSI, the very first hit in the manual is:
"In the CLUTTR menu, the VSI scale can be set to display 1000 ft/min, 2000ft/min, and 4000 ft/min."
The next hit is then the above discussed page 5-8.
We're truly open to making our manuals better, bit really don't know how to make the path to each option cleaner than EFIS->SETUP->CLUTTR->VSI. A big printed menu tree would likely be hundreds of items wide at the bottom, and lots of these would be non-obvious unless you looked upwards in the tree to figure out the context, so that doesn't seem like it makes everything obvious in one stroke.
