wayne4242
Nearly finished installing the Skyview with 1 last anomaly... Fuel pressure from a VDO 30psi pressure sender on a Jabiru 3300 reading on the Skyview Display is about 1/2 what it should be. Using a fully separate meter, I get what I should (around 4 psi at idle, dropping to about 3.6psi when throttle is opened to 2,000rpm). The Skyview sub-menu is set to the correct 30psi sensor. Any ideas on why my Skyview would be displaying 2.2psi at idle, dropping to around 0.6 at 2,000rpm and 0.0 as soon as WOT is applied?
