Magnetic field change. D10a
steve@tiyce.com
D10a How to bring up the page to change magnetic field from Horizontal intensity to Total field. The magnetic field page was there on initial set up with the local airport page.
Since the unit has been configured those pages no longer appear.
It's under SETUP > MAGINC and MAGINT (Note that there are some "MORE" button pushes along the way. The only way they wouldn't be there is if you've previously "locked" the unit (or a manufactured of an airplane did it for you). But this is rare.
steve@tiyce.com
It is not in available MAGINC or MAGINT I have no trouble pulling up any of these pages. However may have inadvertently locked the unit by accident but have had no indication of that. How do I unlock it?
The unit has been configured including remote compass calibration and works well in flight conditions. Will not hold heading to the south anywhere south of the 270-90 deg line . north is ok.
It's very hard to inadvertently lock a unit. It requires a series of very active steps through the support program to create a locking file, followed by a file load of that resulting locking file.
Are you saying that you can't even see the MAGINC or MAGINT buttons?
In any case, you should probably call our support team at 425-402-0433 at this point for more personalized help here. We're getting to the limits of what is easy to explain over the forum.
