Manifold Pressure Sensor Location
swaneymj
Oxnard, CA
:-? I'm installing the EMS sensors for my Skyview system and just got to the MP sensor.  Is it okay to install it on the engine side of the firewall?  I don't see anything in the latest version of the Installation Manual that precludes that.  The material it's made of just doesn't seem like something you'd mount in the engine compartment.
I usually mount them on engine side of firewall - these were made for the auto industry & meant to be mounted there, don't forget to mount it higher than the cylinder you're using for map sensing.
Jake J ;)
swaneymj
Oxnard, CA
Thanks Jake.  That will work well.  I have to "T" it to my electronic ignition MAP sensor, too, and it's on the firewall.
:D
PhantomPholly
:D
What type of electronic ignition do you have? Many are not supposed to be mounted in the engine compartment.
I have both MAP sensor and EE inside the firewall.
Don't forget to place some kind of restrictor in the MAP sensor air line. If you don't, you will get a highly fluctuating MAP reading.
I bought the P-Mags and support told me that the best place to get MAP is from the line to the existing MAP sensor. I plan to T in once for each P-Mag. The E-Mag/P-Mag are self contained so there are no separate control units to mount. It's all in the engine compartment although they neeed to be cooled like MAGs.
I also have a 1/4" line from the #2 cyl primer mount directly to the Dynon MAP sensor mounted on the firewall with no restrictions and have no fluctuation problems. I can see that if the line could hold fluid in a low spot it could cause fluctuations.
I can see that if the line could hold fluid in a low spot it could cause fluctuations. - or damage to the sensor if the fluid gets into it :'(
Jake J
