MAP and other instruments
nleonard
I'm helping a friend install his Flightdeck 180. He has several steam gauges including a MAP, and fuel pressure. I have explained that his fuel gauges can't be connected to the display and the guages at the same time because of the dual voltage sources but what other instruments can or can't be used from a single sender to a steam guage and to the EMS?
The only ones you can really split to steam gauges are the CHTs, EGTs, and RPM. Oil pressure, temp, fuel pressure, OAT, carb temp, fuel level, can't be split. MAP theoretically can, but few devices use our MAP sender. Battery voltage can be split, and maybe amps can, if the same sender is expected.
