Map Items - 30 Hour Trial Period
skypilotusa
Quick Question... I am flying within the 30 hour trial period.
I want to include the ETE Next on the map, but I don't see the option to add it in the Map Setup.  I have tried to find the options to edit the map, on the ground and in flight but no luck.  Do I need to purchase full version before I can add the ETE Next?
The map trial is a full trial with no restrictions.
ETE (Next) is under Map->Map Menu->Info Items
Are you not seeing ETE Next there, or once you bring it up is it not working the way you expect?
skypilotusa
I was not able to find the option to add the ETE (Next). Probably something I am not seeing. I will follow Map>Map Menu>info items tomorrow to see if I missed something. I don't remember seeing an "Info Items" menu option.
skypilotusa
OK... I think I know where I was going wrong. I was going into setup mode 7-8 buttons, thinking it would be there. After reading your post and comparing it to the manual, I see where I should be going... I am in Setup so much these days my figures go there by default... Thanks for help!!
