MAP Manifold pressure units
rcparris
I have a suspicion I'm missing something very obvious, but I can't seem to get MAP to display in 'inhg'.
In the units settings I have:-
Barometric  mbar            -displays correct
General       Press PSI      - displays PSI
MAP            Press inhg     - displays PSI  ????
Is there another setting to adjust?
Many thanks
Are you saying that the label on the gauge display is PSI? Can you take a screenshot of the MAP gauge (buttons 2/7 with a USB stick inserted) looking like that?
rcparris
Screen shots are attached:-
Problem has now been resolved by changing the descriptor from a custom label to MAP in the sensor definitions
Regards
