Matronics and EMS D-120 V. 5.1.1
Jaroslaw
Poland
I have EMS D120 which monitors Rotax 914
For fuel flow I installed Martronics box which works with two flow sensors.
In setup ( sensors/Fuel flow) are K-value and K-value for Return flow. Can I input in K-value K-factor off Transducer, and in return flow K-factor off Return Transducer???
Or Should I calculate K- value , and in Return Flow leave 0 ?
You should calculate the K value, and then leave return value as zero. The return value is for when you are estimating return flow, not when you have an actual sender.
