max set airspeed how can I increase it to 190 knot
valerieflyer
Fort Worth, Tx
Hi, We need to set a higher max airspeed for the pitch servo. I just tried to increase it and the max it would increment to is 176 knots. I can decrement the speed, it appears that Dynon limited the high speed. After level off at 6500 ft. the airplane easily exceeded 176 kts and started to climb at 1000 ft/min. At higher altitudes we are ok but would sure like to use the autopilot at higher indicated speeds. Any advice? We have the latest revision of D10A firmware.
Valerie
You can't set the max speed higher than 90‰ of your Vne. You'll need to set your Vne higher to allow speeds greater than 176 knots.
