I changed my D180 to a SV700 and are having trouble with sensors.
1) Problem with CHT: Indicated Temperature is about 15 deg celsius to low
The D37 cable from my old D180 had CHT 1 and CHT 2 at pins 4 & 22 - I mapped these sensors on my SV700 to the same pins. I tried all sensor types, best result with "Rotax sensords" (which are installed)
I measured resistance of cht sensors and oil temperature sensor (which shows correct value); they all had the same resistance (1.6 kOhm @ 13 degrees celsius)
what else could I do ?
2) Problem with oil Pressure: oil p widget is "crossed out" on the screen, the sensor debug data shows Value "na"
I mapped oil pressure to pin 6 (as it was on D180) and choose the installed Honeywell sensor. d180 and Sv700 both have pin 15 with DC+12, so to my opinion it should work
any ideas ?
3) Voltmeter
SV700 wants voltmeter @ pin 1 or 2 - D180 did not use these - is there any other idea fpr the voltmeter than to connect a new cable to pin 1 ?
thx for your help
any ideas ?
3) Voltmeter
thx for your help
