dabear
I had to reconfigure my installation last night and ran into some interesting … features. This raised a couple of questions:
1. Where is the fuel tank calibration information saved?
2. Can it be input into the system via text file?
3. When there is a difference in configuration between screens, which screen is the “winner?”
4. Are the “non-controlling” screens able to save the “new” data?
I have 3 10” SV EFIS, 2 ADHARS, 1 EMS, 1 GPS, 1 Dynon XPR. When trying to reconfigure the sensors (from capacitance to resistance ) and move them to new pins/sensor locations I ran into a problem. I changed the configuration on my primary screen and saved the data. Upon rebooting the screen the information went away and was back to the original install version.
This happened a few times, and then I decided to leave screen 2 & 3 OFF while doing the config. I then copied the config files over to the other screens prior to booting all 3 together. I saw this behavior when doing the first install (EMS layout) but didn’t try and track it down. I thought it might be the “first” screen that boots gets the control, but it didn’t work last night. What I think I saw was that the screen with the lowest S/N got the “control.”
I was able to calibrate the fuel tanks with the primary screen. But now I’m worried about where that configuration is so that I can transfer it over to the other screens before the primary gets over written. Where is that information held?
While configuration changes should be rare, for those of us with multiple SV screens can I ask for a feature change?
1. Assign a screen the default “lead” and all other screens take their configuration from that screen unless its not up.
2. Be able to “PUSH” the configuration from the primary screen to all others in the system.
3. Upon boot of the screens, they talk and confirm they are all using the same configuration/data files
Thanks for listening.
