Multiple flight plans
hlangebro
I don't know if anyone has covered this before, however I couldn't find any posts. The tpoic is to be able to save multiple flight plans in skyview. Currently you can only have one flight plan in there. It would be nice to be able to save up to 10 different flight plans and then pick from the list the one you want to use. Has this been discussed before?
You can do just this. You can save flight plans to a USB stick and recall them. You just need to leave a USB stick plugged in to your screen.
preid
SoCal
I assume you mean save the flight plans to the skyview so if you forget a USB stick it is on the skyview for easier future access.
I raised this in the past. I also liked the way the flightplans were far easier to pull in previous builds were one simply moved to the right and loaded a flightplan. The newer version requires more steps and a D-> to activate the flightplan.
Less steps and having a easy way to get a flightplan off the Skyview itself and automatically load the first leg would be great for a future consideration!
