Network Hub shielded?
cjohngraham
I plan to run a 6AWG wire 2-3" away from the SV network hub to power a VP-X Sport box. It's fairly crowded behind the panel, and this is the most direct route. My network cables (assembled by SteinAir) are shielded, but I'm wondering if running the wire close to the hub could cause problems within the hub itself. Does the hub assembly provide any shielding for its internal wiring?
No shielding or spacing is needed for SkyView network wires. The network wires Dynon sells are not shielded. The signaling used for the network is very low noise and very robust. You can wrap the wire around the main aircraft power wire to the battery and it will still work fine, so 2" of space is plenty.
