New 912s/ oil pressure sensor
JT701
I 'm wiring the 912s to the D180 and the oil pressure sensor has two(2) wires one red and one white. the instructions indicate that there is only one wire coming from the oil pressure sender. How do these two connect to the D180?
Thanks for any help,
Tom
Tom,
You have the newer Honeywell sensor on your engine. This is supported, but you need to use a newer D180 manual if you have an older one. It's page 3-6 in the current manual, which you can download off our site if you don't have it.
JT701
Thanks for the quick reply. Yes, I do have the older manual so I will down load the new part I need and see how it goes. Because of the cost involved in building things have been going slower than I had hoped for so, between purchasing the D180 and the 912s a few years have passed.
Thanks again,
Tom
