new EMS 13.0 update deleted fuel calibration
david.perl
i have dynon capacitance sensors so used the separate EMS update patch. On updating it lost the pin assignments for the capacitance sensors so i had to remap these. On remapping i noticed its lost the calibration for each tank.
is there a way to get the calibration back?
What version were you coming from? If one of the more recent software versions, there's a copy of the settings backed up to USB stick in a subfolder you upgraded with. If you have a settings backup, the calibration will be in there. First lets see if you have that, then we can get into getting it back into your current system.
david.perl
it was the most recent version, i think something like 12.2???
in the settings archive on the USB i have the following 4 files:
2015-08-06-G CILG-SN7638-12.0.0.2780-SW_UPGRADE-SENSOR_CONFIG.sfg
2015-08-06-G CILG-SN7638-12.0.0.2780-SW_UPGRADE-USER_CONFIG.dfg
2015-08-06-GCILG-SN21631-12.0.0.2780-SW_UPGRADE-SENSOR_CONFIG.sfg
2015-08-06-GCILG-SN21631-12.0.0.2780-SW_UPGRADE-USER_CONFIG.dfg
So it looks like you upgraded from 12.0, and that's fine. It'll be in either of the .dfg files (one is from each display). If you haven't changed anything since you've upgraded, this should get you back in business:
-Copy either of the .dfg files out from the folder that it's in and into the "root" of the USB stick.
-On your SkyView, Go to SYSTEM SOFTWARE > EXPORT SETTINGS and save off a copy of your current settings. This will get us a way to get you back to your existing 13.0 settings current if the next steps don't go 100% right (it should)
-Go go SYSTEM SOFTWARE > LOAD FILES > and load the 12.0 .dfg file (the one that was already on the stick, not the one you've just saved).
-Exit setup. Restart booth displays. Confirm fuel cal and widget are back.
david.perl
many thanks
Does this need doing on both displays? If so does it make a difference which on is done first?
You only need to do this on one display and it doesn't matter which one as long as the other one is on at the time you do it.
