10ixwwybk2
- Joined
- Jun 7, 2011
- Messages
- 27
I ran the O320 engine in my, RV9a equipped with twin Skyviews, for the first time today.
I am not very Avionics savy and would appreciate some advice on the following issues
The Lycoming instructions say switch off immediately if the oil pressure does not rise, I found. that the power drain of the starter causes the Dynons to re-boot, it is then over a minute before you can see your any output from your EMS.
I went ahead and when the screen re-booted it showed a good oil pressure numericaly, but the digital scale had a red cross on it and was not working. I checked the 'sensor setup' and it seems to be correctly formulated in the same manner as the other displays.
I also had a some other problems.
The carb heat said it was not connected. I will check the curcuit. I assume it is a variable resistor to ground, can anyone tell me the resistance range of the sensor.
I did not have a voltmeter reading. There was a simple solution, I did not connect the red wire, pin 1. It was not mentioned, as far as I could see, in the instructions. Can I connect this to any +ve source.
Many thanks
Robin
Many thanks
Robin
