I am installing a new FlightDEK-D-180 (firmware version is 1.08) The unit seems to be working fine, but the backup battery isn't charging.
The unit initially worked off the battery for a short time when it arrived.
I checked the voltage at the Dynon output battery terminals and it's zero.
I have connected both the red (pin 1) and the yellow (pin 2) power; and ground pins 3 and 16 on the DB25 EFIS connector.
Is there a 'battery installed' setup I'm missing, or a fuse that is field replaceable?
Thanks in advance,
Jeff
Thanks in advance,
Jeff
