mikehoover
- Joined
- Sep 12, 2005
- Messages
- 63
Dynon's announcement of the new Kavlico pressure sensors has got me to wondering if I should plan ahead in my wiring. I have not yet closed up my wiring (Vans RV-9A).
The newsletter says the new Kavlico sensors will require an additional wire to provide the sensor a 5 volt source. So, I am trying to figure a good solution to prepare for future upgrade to the new sensors.
Should I run a 5 volt wire from my main buss via and convert from 12 v via some sort of regulator?
Is there a spare 5 volt wire from the EMS that would accommodate the sensors?
I expect I would be replacing only the oil pressure and fuel pressure sensors at some point in the future (ie, as/if they fail).
I could run a 5 volt wire to the FWF area and stub it out now and tap into it in the future.
Comments/suggestions?
I have a Lycoming O-320 carbureted installed.
Thanks!
Thanks!
