Here's how the system works:
Power goes to the screen.
The screen takes that power and powers itself.
It also routes some of that power out to modules on the DSAB bus. These are remote boxes, but they are powered by the screen.
Multiple screens can power DSAB, so if you have 2 screens and one fails, the other takes over.
If your master power fails, the battery in the screen powers the remote module(s)
Nothing has changed since Oshkosh, this is how it has always been designed. While the boxes like the AHRS and EMS are remote, they use a single cable connection to the screen, which is both power and data. The installer doesn't run separate power to the modules.
As you can see from this, the power draw for the screen can be highly dynamic. If you have two screens, one won't draw very much power, since the other will be powering basically everything. But if the one powering everything dies, the backup one draws much more power.
