NMEA Output
8181C
Has anyone yet interfaced the NMEA output to a FS-450 or EI fuel computer? I see there are lots of NMEA outputs in the pinout information. Has this part been activated yet? :D
8181C
I assume this feature will be in a future build than? :-?
8181C
If I wanted to prewire for the NMEA output when it is available, Would I use one of the serial outputs? or would youmost likely use one of the pins not yet assigned? ::)
You'll be able to choose any of the 5 configurable serial ports to send the NMEA stream out of once it's available.
