No ADS-B out
laser2300
I have Skyview Classic D1000, SV- 261 transponder, GPS 2020. Transponder is on serial port #1 of the display, & GPS is on serial port #5 .
The transponder outputs properly (according to ATC and it is controllable thru the display. GPS position is received as map and GS functions are normal. I have double checked hex code and aircraft data in the setup. Problem is I have failed to successfully generate an ADS-B performance report and others with ADS-B receivers cannot 'see' my info. What am I missing?? Tks
kellym
Check your transponder setup. You must select the GPS2020 as the source for position.
