No AOA audio
tomkk
RV-12 ELSA
Port Orange, Fl
I've just added AOA to my RV-12. I'm getting the AOA bars and they seem to be working correctly and I'm getting a "SPD' visual warning at the top of the PFD at the appropriate time but no AOA audio. I've done System Setup | Audio setup | AOA begin at bottom of yellow, AOA vol 100%, Inhibit AOA below 20 kts, Alert vol 100%. Other (non-AOA) alerts are working correctly. I must be missing a setting somewhere.
Should have mentioned I'm running the latest Skyview (13.0.3) and I went through the IAS/AOA cal on the ground and the AOA cal in the air.
I think you've covered all of the settings you should need to. You might try turning the inhibit down even lower just to make sure that's not chopping the audio when you don't think it is. Do you have one display or two? If two, do you have audio hooked up to both displays in parallel? You might also take a quick video of AOA in action (not in cal mode) so that we can see that what you're seeing is what you should be seeing. You can email a link or a short clip to support at dynonavionics dot com.
tomkk
RV-12 ELSA
Port Orange, Fl
Inexplicably, when I flew today the audio worked correctly. The only thing I can think of that occurred was I powered down the system yesterday and powered it up today. Is it possible that it takes a power cycle after calibration? But then again, everything except audio worked yesterday so that didn't take a power cycle to make it work.
Anyway, however it happened, I'm up and running and it works great.
