No Glides slope
cjhukill
I have a G430W hooked up thru an Arinc 429 box to my Skyview, with a Stein built harness and I can't get glide slope. I have played with all the settings, and consulted Stein's people and Dynon tech support and none of their suggestions have worked. The GS was working fine with the old indicator, but not the Skyview. Has anyone else had this issue and had success fixing it? The local avionics shop said there is no way to tell if the G430 is recieving it without seeing it on the Skyview other than removing it from my plane and installing it into another.Help!
timfwalsh01
Alexandria, VA
I just came from the airport.  I am having the same problem.  Started after loading 5.0.
The GPS signal works well.
I thought it was a bad ARINC box, I was promptly sent a new one.  Still not working!!
When I go to the setup page, ARINC is not recognized.  Did a force load - no good.  It is getting power, the red light is flashing, just not being recognized by the system.
Thougths?  Tim
Tim - Please get in touch with our support dept to continue working with them. They'll be your best resource to attach this.
cjhukill - Are we talking GS when tuned to an ILS or on a GPS approach? If GPS, check that the Main ARINC 429 Config Page > VNAV setting is set to "Enable Labels"
