New install with an HDX800 and Dynon Gray Code converter feeding a Garmin GTX320. ATC receives primary target but no Mode C. Xpndr back lighting work and I get a reply light on the xpndr when flying. Things I've tried so far:
1. Verified HDX800 serial port (4) settings are correct per the Dynon manual. It shows data transmitting on the Setup page.
2. Verified the Dynon Gray Code twisted pair connection to the HDX800 Dsub 37 pins (Green to pin 10 for serial-4 Tx and black to pin 23 for ground).
3. Reinstalled all the output wires from the Gray Code converter to the xpndr Dsub25. Triple checked the pins numbers are correct. Checked them again 4 more times.
4. Removed the Gray Code converter power input wire from the xpndr power output pin (xpndr pin #14) and wired it directly to the xpndr circuit breaker to make sure the converter is getting power.
5. Verified the xpdr connector is fully seated.
Question: Is there anything I can check/troubleshoot to verify the Gray Code converter is correctly supplying altitude info to the xpndr? I'm more suspicious of the xpndr at this point but would like to verify the correct altitude data is being provided before I tackle a xpndr repair. Yes, I know the Dynon transponder is the ultimate solution and that is my plan in a year or two. I'd like to fly for a while with this 'old-style' transponder while making a fiscal recovery from the recent completion of my aircraft.
Thanks,
William B., Cozy Mk4 - N494WB
Thanks,
