NRST distance frozen
cjohngraham
Sometimes when I push the NRST key, the distance to airports is frozen, i.e. today I was returning to KSAF and NRST showed 26 nm (the same as a few minutes before), while the distance remaining in the flight plan side bar was correct, 15 nm. How to fix?
I've noticed that the NRST distances don't change and recalculate the distance/bearing as you continue to fly - they are fixed at the time of pressing the NRST button. If you press it again you should get a new "snapshot".
cjohngraham
That's the problem. Closing the NRST window and then pressing NRST again doesn't change the values.
