Yes, it certainly could. The recovery factor would vary with the mounting location, as well as the probe type. The more the OAT probe is buried in the boundary layer, the lower the recovery factor will be. Prop wash could also complicate things.Hey Kevin,
Wouldn't ram temperature rise also depend on probe placement?
Also, for NACA scoops on the forward fuselage, typically the inboard end of the OAT probe would be exposed to cabin air. If you are using cabin heat, this would likely affect the temperature sensed by the OAT probe.I think you will find the NACA unacceptable. Two factors work against that location; the heat from the engine escapes from the cowl and will raise the local temp at least several degrees and the sunlight falling on the probe in certain attitudes will also cause an elevated reading. A location under the wing or empanage, away from engine and exhaust air should be your goal.
