OAT Connection
  • Thread starter Thread starter Bill Repucci(Guest)
  • Start date Start date
B
Bill Repucci(Guest)
Yesterday I installed the OAT probe in my RV-9.
When I opened the manual to connect the wires it tells me to "Crimp female pins into the yellow and red wires but leave the blue wire/shield combination bare. Plug the yellow wire into pin 2 on the female D9 connector which mates with the EDC-D10A. Plug the red wire into pin 7. Connect the blue wire/shield combination to the same ground that feeds the EDC-D10A through Pin 1.”
The problem is the wiring harness I purchased from you and made by SteinAir doesn't match up to these directions.
The OAT wires are both white with black stripes and the StineAir wiring harness had me connect the remote compass wires in the following manor:
White/Oragne - Pin 5
White/Blue - Pin 6
White/Green - Pin 9
White - Pin 1
What have I done wrong? Where do I connect the OAT probe to? Sounds like I will need to cut some pins off and crimp two wires to one pin to tie in to the compass, is that right?
The OAT with just two wires that are both black/white is the EMS OAT. I'm assuming you do not have the engine monitor. If this is the case, give us a call at 425-402-0553 and we can get everything sorted out.
I do have the EMS D10. What I don't have yet is the D100, only the wiring harness, tray, pitot tube, etc. I'm waiting until the last minute to buy the actuall electronics.
Will call in the AM.
Thanks for the help.
Bill
Back
