C
canardflyer(Guest)
OAT:
Thanks for the prompt delivery of the replacement OAT probe. I received it on Friday as expected.
Replaced the old probe with the new one and the OAT value showed up on the display. Thanks!
Serial-Parallel Encoder Module:
I have a Narco AT150 gray code (parallel) xponder. Ever since I upgraded the D10 to D10A with the serial to parallel encoder coverter, I don't seem to get altitude encoding. Few weeks ago I did an inflight xponder check with the local approach control with negative results. Recently, I took out the AT150 and checked the wiring and connector and even replaced a suspect connector pin. Today I did another in-flight check with still no altitude encoding on my signal. Is there an easy way to check the encoder converter module? Any help on this matter will be greatly appreciated (considering that I fly out of an airport which is very close to the mode-c 30nm zone around LAX).
EFIS Data Log File:
I also logged a couple of minutes worth of data on the ground with engine off to check out the serial interface. Moved the airplane in yaw a bit and varied the baro-pressure. It all registered in the data stream as expected.
I parsed the data stream to plot it and noticed that the second count increment has a consistent five step (1/64th second step) lag at the end. It showed up as non-causal data points when I tried plotting the data against time. Below is an excerpt of the data file, with the affected second and frac. of second lines underlined. Note the second field takes five extra sample before it increments.
12224160+002+00013380000+0041+001-00+1099002BF60181
12224161+002+00013380000+0041+001-00+1099002BF60182
12224162+002+00013380000+0041+001-00+1099002BF60183
12224163+002+00013380000+0041+001-00+1099002BF60184
12224100+002+00013380000+0041+001-00+1099002BF6017B
12224101+002+00013380000+0041+001-00+1099002BF6017C
12224102+002+00013380000+0041+001-00+1099002BF6017D
12224103+002+00013380000+0041+001-01+1099002BF6017F
12224104+002+00013380000+0041+001-01+1099002BF60180 *
12224205+002+00013380000+0041+001-01+1099002BF60182
12224206+002+00013380000+0041+001-01+1099002BF60183
12224207+002+00013380000+0041+001-01+1099002BF60184
EFIS Data Log File:
