OAT VALUE DOES NOT CHANGE
Michael
I installed the remote compass module and the OAT probe.
The D10A was then installed and connected.
The probe has been configured but despite what the outside temperature is
the D10A always gives a value of 15 C. Even if mild heat is applied to the probe, the value does not change.
In the setup, on OAT 1 the value is 0, on OAT 2 the value is 15 C.
The menu shows OAT not OATADJ as indicated in the setup instructions.
The software version is 02.09.01
How can I get the OAT to read the correct value?
I had the D10 and the compass module upgraded.
Did I also need to ge the OAT upgraded as well?
Hi Michael, we apologize for the problem you're seeing. We often see this problem when the EDC-D10A has mismatched software from the EFIS-D10A. I.e. your EFIS shows software 02.09.01, but your EDC has a previous rev of software on it. This is our fault, and we've since put protections in place to make sure that that doesn't happen again.
To solve your problem, you simply need to reload the latest software (02.11.00, available here) on your EFIS-D10A with your EDC-D10A connected. This will reprogram the EDC correctly and you should see the correct OAT value. Let us know if this does not work.
