I've installed the OAT sensor on a Dynon D100 per installation instructions
Initial reading is about 13 degree centigrade. Air temperature is 27 degree c.
The adjust limits are plus or minus 10 degrees C so ambient cannot be set The screen will show "not installed" when disconnected.
Setting the indication at maximum seems to get no indication change with temperature however a decrease in temperature will show when "zeroed" and the temper changed.
