I have recently changed my fuel and oil transducer to the kavlico. Since the change I have noticed when I run into some turbulence that my oil pressure reading jumps around, from 70 to 90 or 70 to 50 psi...then once I am back on smooth air it stops jumping and is steady at 70 psi. I need help as to why?
I have the fuel and oil pressure transducer 5 volt wire connected to the red/white 5 volt wire from the db25 as well as the manifold pressure wire on the 5 volt. Maybe another one too (fuel indicators), I will have to check my wiring schematic again, but basically I have multiple wires (at least 3 maybe more) connected to the 5 volt pin from the db25.... Could that be the issue.
Please advise
Please advise
