OIL PRESSURE
philcie
hello, I'm trying to fix my oil pressure probleme
first I made myself a wiring harness from d37, but I was enable to fix my oil press
I baught dynon complet Harness in color
I reinstall every thing, but still enable to get oil press all other sensors working
in sensor type on setup config  1 and 2 read  in red --- and in 3 =263psi or more
the sender working great at 2 bars read 51homs, 3 read 75homs and 4 bars read 75homs, i put the sender on fuel pressure (brown wire) for a test with air pressure to control and it show a pressure at 2bars on d180
in any condition, the D-180 can't tell oil pressure
all ground are tested and in good contact
can you tell me what to do, I can't fly anymore with no oil pressure
philippe cie :'(
Your resistances measurements sound good, and based on your on-screen reading of off-scale high, it sound like your sensor isn't electrically connected to the EMS. So, it might be a pin that isn't seated in the DB37 connector, or a broken wire in the harness, or a bad ground path back to the EMS.
May be a good idea to check all the connections - I just recently found a 'bad' Dsub connector that, although the socket clicked in, a gentle pull on the wire allowed it to come out - just one of those things that happen rarely ::)
Jake J
philcie
thk you for the prompt answer, i will control tomorrow, i'll give you news
