jaba-who
I have installed a D 180 with a Jabiru 3300 engine (which has not yet run)
and am having a problem with the oil temp and Pressure readings.
The engine has no oil in it yet and is sitting at ambient temp in the shed.
When I connect up the oil temp and pressure probes to the dynon they both read full scale.
If I disconnect them and connect up the old Jabiru analogue gauges both gauges show low readings.
Also I am getting a reading of about 670 on the MAP scale on the Dynon but I don't have a probe connected to the wire.
Any hints as to why I am getting the high readings on the Oil T & P and a reading at all on the MAP?
John Martin
John Martin
