I have standard Lycoming 6 cyl fuel injected EMS sensors on an IO-540. All connected sensors are displaying correctly except the oil temp when EMS screen is on 50 percent layout.
In other words, for 20 percent and 100 percent layout the oil temp display is normal and correct.
On the 50 percent display, it shows red X and no temp, even though the needle display moves when heat is applied to the sensor. :'(
I tried deleting the oil temp sensor display from the 50 percent layout and then adding it back. Still does the same. I have dual D1000, with dual ADAHRS, dual stdby batteries, VPX power system.
