Old EMS D120 - installing a SKYview ?
F-PPRQ
I have a EMS D120 installed on my experimental homebuilt DR250 (4 seater Jodel-Robin , IO 320). This EMS is an old "normal " (not super-) brighnes screen ... less and less bright.
This EMS work fine (excepted brigtness). I have in mind two options : i- send the EMS to bee reparaided (I know upgrading to super brightness is not possible now), ii-install a new Skyview (without com fonctions).
Question :
- is connections with engine probes (EGT, CHT,RPM, MP, Oil t° and presure, fluel flow and presure, tanks level gauges, OAT... ) can be re-use (and plug and play ?
blue sky
jp
The connectors are the same, and the connections inside them should be too. But the way you connect them looks a bit different. The wiring harnesses you have would connect to a SV-EMS-220, which would connect to a network hub, and then to the Skyview EFIS.
You can verify the pinouts are the same with these two documents:
Starting on page 2-4.
Starting on page 10.
