Sportsman7064
All,
Looking for help. I have dual SV system with two-axis Autopilot. Running a configuration of the network, or looking at the status, the system only sees one of the two servos. With wiring as the most likely culprit, I checked that power is getting to the wires that come directly out of the servo. I also disconnected and re-connected the network wires to both, and can only get the one servo to show up when I run a configuration of the system.
Is there anything else I can check prior to sending the servo back to Dynon?
Russ
Russ
