Ongoing problem
hornet2008
Mudgee NSW Australia
I continue to solve the problem of %power and fuel flow. Are the two related in the Skyview Touch? I had the unit returned to Dynon as there was a problem with it powering up and displaying two Xs. It was supposed to be fixed, still does it every time I power up. I’m in Australia and it was well over a month turn around and $1000. I put up with it as I can’t afford to send the unit back on the off chance it’ll be returned without repair as happen last time.
skysailor
Dynon Tech Support will answer by email if you contact them but I do not think fuel flow is part of the calculation. I believe it uses density altitude, RPM, and Manifold pressure. A likely culprit is not having a temperature reading which would cause density altitude problems. Do you have a steady density altitude reading (just below VSI tape)?
